[Za...] Posted July 25, 2023 Share Posted July 25, 2023 Has anyone ever run into an issue with their Secondary Alignment causing items using that alignment to go to the wrong coordinates? The only time I've ever seen this happen is when the nominal points/path are off in space somewhere, but my nominals are right where they should be on the cad according to the secondary alignment and the probe is trying to go through my part. I'm going to have to end up doing caliper distances to report these locations, but I figured I'd ask here to see if there's anyway around this? To start off, the CAD model is already off on some features (.5/1.0/1.5mm diff from print). Link to comment Share on other sites More sharing options...
[Ri...] Posted July 25, 2023 Share Posted July 25, 2023 My first guess's would be your tertiary feature. What axis is it setting in your alignment? Is it the correct type of feature for a tertiary? Link to comment Share on other sites More sharing options...
[Za...] Posted July 26, 2023 Author Share Posted July 26, 2023 Please sign in to view this quote. Rick, it looks like it's an issue with the CAD model itself. The .stp is 3x as large in file size as the previous model that was used (I'm actually recreating a program from scratch on this one) and the nominals didn't match. Unfortunately I finished the program before figuring out the issue. I'm reverting back to an old model now that seems to have the correct data, hopefully this one works. Link to comment Share on other sites More sharing options...
