RDS multiple stylus qualification
I am inspecting a snap ring groove using a stylus system on an XXT with two styli mounted in the #2 and #4 positions (+/-Y) on a star adapter. The RDS angle for measurement of the groove is A:0° B:-90° and both styli have been qualified individually.
I am setting up a mirrored part and need to use this stylus system angled at A:0° B:90°. I am relatively new to Calypso and unsure of how to manage the qualification of the two styli at multiple angles. Do I have to overwrite and re-qualify the angles of each when switching between parts or is there a way to have multiple angles associated with the same stylus on a star setup?
https://qualityforum.zeiss.com/topic/7566-rds-multiple-stylus-qualification/
Just wanna make sure I read correctly you have a stylus system with only 2 probes on it @ #2 and #4 directions. If that's correct you could rotate your head to "90, 0" so the probes are facing #3 and #5 then calibrate them individually like that you don't overwrite them, just rotate to the angle you want name and qualify it
