[ku...] Posted January 29, 2021 Share Posted January 29, 2021 Is everyone here leaving GOM ct scanner on, even if its not being used? Link to comment Share on other sites More sharing options...
[Ja...] Posted February 11, 2021 Share Posted February 11, 2021 Hello dave, when you are not using your GOM CT it is recommended to just turn off the radiation and leave it idle. When you are not using your system for two weeks or longer you should turn off the whole GOM CT via the main power switch. Kind Regards, Jannis Link to comment Share on other sites More sharing options...
