go-to position without probing
We have a need for a calypso program that will move the probe head to several locations within the measuring envelop of our Contura. We want the probe head to go to each location, pause for 10 seconds, then move to the next location. This program is for calibration of an optical machine which will be "watching" the probe head and making its own measurements, external to calypso. Can calypso be programmed to move the probe to these positions and pause without measuring any features?
https://qualityforum.zeiss.com/topic/7618-go-to-position-without-probing/
Absolutely. Like John said, you need PCM to use the wait() parameter in a programmable stop in the feature (point) strategy. So you would have the clearance data, position CMM without probing, then the programmable stop with the wait() parameter in the text box (I believe. I don't have access to PCM anymore so that might be wrong).
