Stylus wants to go through part to probe these planes.
Sounds like some edges might be blocked.
Plan > Navigation > Block Edges
If that looks OK, next I would verify the retract distance on those features.
Block edges looked fine, i had to put the retract distance pretty low for it to work. Thank you!
Also, try using a +Z clearance plane. Probably won't need position points but the image is not clear and don't know your exact probe configuration.
Well
- for upper plane
  • check if it is -Z direction
  • CP +Y, probe -Y
  • safe distance to ZERO
  • retract distance to more then R of probe
- for lower plane
  • check if it is +Z direction
  • CP -Y, probe +Y
If you can not clearly approach further points, then consider polyline, where your start and end will be closer to CP - otherwise you have to use position points - CAREFULLY
Other solution would be custom angled probe from +X direction.
That's an internal slot wall plane that is at an angle. You cannot get safely in and out of the feature without either starting and ending at the very beginning of the wall, or using position points.
In 2022 and beyond, they added the option to approach via the stylus direction which would alleviate your issue.
