[Ty...] Posted June 19, 2023 Share Posted June 19, 2023 Hello everyone, Has anyone ran into a problem like this?? my polyline scans are showing completely away from the feature that its meant for. It just started doing this randomly and I'm unsure how to fix it. Its doing to all features. We are running Calypso 2019, version 6.8 I believe. ThanksSnaping.JPG Link to comment Share on other sites More sharing options...
[Ju...] Posted June 19, 2023 Share Posted June 19, 2023 Whenever this happens to me, the graphic usually corrects itself after the feature is opened. Link to comment Share on other sites More sharing options...
[Ty...] Posted June 19, 2023 Author Share Posted June 19, 2023 Please sign in to view this quote. I was hoping for that, and it didnt work for me. Link to comment Share on other sites More sharing options...
[Ju...] Posted June 19, 2023 Share Posted June 19, 2023 Is the feature using the base alignment or a secondary alignment? Link to comment Share on other sites More sharing options...
[Ty...] Posted June 19, 2023 Author Share Posted June 19, 2023 Please sign in to view this quote. base alignment. its every feature on the part that does it. it didnt do it earlier today Link to comment Share on other sites More sharing options...
[Ju...] Posted June 19, 2023 Share Posted June 19, 2023 Have you tried closing and reopening the measurement plan? Link to comment Share on other sites More sharing options...
[DW...] Posted June 19, 2023 Share Posted June 19, 2023 Please sign in to view this quote. Try this first. Then Resources>Utilities>Set Base Alignment to Zero. Perform a manual alignment. I think I have had this happen before and I had to reset the base alignment values. I might have even had to delete the base alignment..Try the other steps first. Link to comment Share on other sites More sharing options...
[Da...] Posted June 20, 2023 Share Posted June 20, 2023 Did you translate the model to the correct position? Did you run a manual alignment? Link to comment Share on other sites More sharing options...
[Ri...] Posted June 21, 2023 Share Posted June 21, 2023 I've had this happen by using the wrong probe tip. Link to comment Share on other sites More sharing options...
