Header Variables
Under " Select report header parameters " I selected Customer and Lot ID. I have force input at start on, whenever I run it always comes up to enter the 2. When it outputs the PiWeb report it only shows customer. I have the generic template for the standard protocol that PiWeb comes with, which has customer on it already but no lot ID. After looking up some videos I was only able to find 2017 version and theres some options on it that is not present in 2021 version. Feeling lost could use some help. On the PiWeb editior I've removed all of the parameters I don't want but I don't know how to link my inputs on calypso to be reported on the header. Thats the part I'm asking for help on. Thanks everyone that can help.
Hi Zachary,
Try to find out which K-Number you need from protocoll head definition first.
Slowly with the mouse along the edge of the column to the variable and with a little luck and patience you can see the K-number. 4485_bb0ac1fbbfde08d227b777a051177821.png
Get it and then open the PiWeb editor and insert this K-Number. Copy an existing element if you want to add or simply change one existing by change the K-values given by the "mouse-over-method"
Check the main manual chapter 8-18 for a list of possible K-values. But be warned: it´s sometimes not working using this numbers or not all K-values are listed.
I just try to use K-1062 ( customer ) but I get allway´s the message that this K-value is not valid 😕
Best Regards
Karsten
Karsten, you explained this process well. It is excruciatingly tedious and slow. There has to be a way to improve this process by eliminating the need to rely on mouseovers and small activation zones.
