[An...] Posted June 13, 2023 Share Posted June 13, 2023 Is there a way to create a PDF, text file, or excel document with syli qualification data? I would like to be able to generate a report that shows when each styli was qualified. Currently I am clicking through the "stylus system management" screen for each styli which is cumbersome with 12 styli on each machine. Attached screenshot is the data I am referring too. Thanks in advance Link to comment Share on other sites More sharing options...
[Je...] Posted June 13, 2023 Share Posted June 13, 2023 You can print the data after calibrating the probes. We use the "Default report". There you have all data. I save it as multiple report --> Default report --> Default report (ASCII) as PDF file. Kalibrieren_Gesamt_2023-4-28 07_35_46.pdfFetching info... Link to comment Share on other sites More sharing options...
