[Ow...] Posted June 8, 2023 Share Posted June 8, 2023 1st off, I don't know a lot about computers, graphics, memory, etc. That said, I.T. just replaced the hard drive on the one I use the most and it's now slower than molasses, it didn't used to be. When running curve and pi-web reports, the vwnt.exe 32 bit shows very high CPU usage and everything stalls for a bit. 😡 Didn't Calypso upgrade to 64 bit? Running version 2021. Link to comment Share on other sites More sharing options...
[Th...] Posted June 8, 2023 Share Posted June 8, 2023 The CAD kernel is 64 bit, but the interface is still 32 bit. Link to comment Share on other sites More sharing options...
[Ke...] Posted June 8, 2023 Share Posted June 8, 2023 This is nominally to fix an error, but the steps found in this article (https://portal.zeiss.com/knowledge-base ... id=1596796) may help speed things up somewhat, particularly with regards to graphical handling. Link to comment Share on other sites More sharing options...
[Je...] Posted June 8, 2023 Share Posted June 8, 2023 Please sign in to view this quote. Yes, yes it is. But, the real question is, "why?" 64 bit is loooooong overdue. 32-bit software is limited to addressing only 4 GB of RAM, while 64-bit software can theoretically address up to 18.4 million TB (terabytes) of RAM. Link to comment Share on other sites More sharing options...
[Je...] Posted June 8, 2023 Share Posted June 8, 2023 CALYPSO is 32-bit as of CY23. CY24 is being developed for full 64-bit. Most of CALYPSO has been 64 for years except very specific areas that are mostly unneeded for processing optimization. If your calculation time and CPU usage is excessive during Curve, be sure to adjust your Curve "Max Search Distance". My personal rule of thumb is 5x tolerance stack-up. So for a .200 tolerance zone in the base alignment I would go with a Search Distance of 1.00. If you leave yours set to a default of 5mm and your evaluation 10-15k points per Curve with mutiple Curves with tight tolerances, your evaluation time will be significantly higher than necessary. Please sign in to view this quote. Thank you Kevin. The important factor that is easily overlooked from that article is that if multiple versions of CALYPSO are installed, EACH version of CALYPSO must be set individually. VWNT.ext as well ACIS.exe from any and all CALYPSO program file directories. Link to comment Share on other sites More sharing options...
[No...] Posted June 12, 2023 Share Posted June 12, 2023 Please sign in to view this quote. 18.4 million TB ought to be enough for anybody. Link to comment Share on other sites More sharing options...
[Je...] Posted June 12, 2023 Share Posted June 12, 2023 Please sign in to view this quote. You say that now...I remember when we said that about 3.5" Floppy Disks, and 1mb/s internet download speeds and 1 GB Hdds...and 1 TB Hdds 🙂 Link to comment Share on other sites More sharing options...
[Je...] Posted June 12, 2023 Share Posted June 12, 2023 Please sign in to view this quote. Haha, so true. My first introduction to a computer involved waiting 45 minutes for a cassette tape to load programs onto a commodore 64 pc. If I fell asleep during this wait and missed the 30 second window to hit the enter key, I had to start all over. But man... playing that 8-bit snakes game on 64k of RAM was exhilarating. . . Link to comment Share on other sites More sharing options...
[Ma...] Posted June 12, 2023 Share Posted June 12, 2023 Please sign in to view this quote. "640K ought to be enough for anybody," Bill Gates, 1981 Link to comment Share on other sites More sharing options...
[Ju...] Posted June 12, 2023 Share Posted June 12, 2023 Please sign in to view this quote. I remember our first family computer had a sticker on it that said, "SPACIOUS 4GB Hard Drive!" Link to comment Share on other sites More sharing options...
[No...] Posted June 13, 2023 Share Posted June 13, 2023 Please sign in to view this quote. That was an ironic citation 🤠 See Mark May's posting further down 😉 Please sign in to view this quote. You should have bought a ZX Spectrum. It showed this nice psychedelic pattern of dancing stripes to keep you awake (or hypnotize you) while loading. 😃 Link to comment Share on other sites More sharing options...
