7.4 Auto Run
What do you do if .arn was overwritten by a part program? Auto Run is not keeping the Layers we are having to open the program folder every time. I suspect the .arn was overwritten could be causing this. The only one I see is in inspection folder. Hopefully there is another place, and this is not the issue. If it is not, I am at a loss for why the Layer drop down is not working. This is on a brand new Contura.
  • 1 month later...
.arn cannot be overwritten by an inspection. Only AUTORUN can write to the .arn file. Its storage location can be where-ever you define it.
