Mutiple printout
Resources > Printout header parameters is for custom printout. The report was created from Multiple Printout under Measurement plan(where Base/Start Alignment, Clearance plane etc are located.
Go to the Multiple Report button under Measurement tab. In the "Definition of Multiple Report" popup box, click on "Select report header parameters". In the "Select report header parameters" popup box, right click the check mark button at the top, a side box will appear. Select "Run" and "Measurement Plan". A check mark will appear in every single box in the popup. Go to the "Resources" menu, go down to "Report header parameters...". The "Input Parameter" popup box will appear. You should see every single available report header parameter available to you. Somewhere in there (most likely under the "Supplier" parameter) you will see "Starke Machine." Once you figure out what parameters are what (write down the parameter names required for your reports), I would click "Force Input at Start" in the lower left of the "Input Parameter" popup box. Go back to the "Select report header parameters" popup, and only check the parameters you want to popup after selecting "Run". This way, when you go to run the program, you select "Run", the "Start Measurement" dialog box appears with the usual options, then you click "Start" and the next popup will be the things you want to show up in your report header. You can modify them or leave them be. Also, if you would like to use the same parameters on future programs during setup, you can save the protocol header data by clicking the "Save" (floppy disk icon) in the "Select report header parameters" popup box.
This is incorrect.
There are (2) types of Header Fields:
- The first is Part related Header Fields. These are typically things that do not change from run-to-run. An example of this would be the Drawing Number or the Part Name/Number, etc.
- The second is Measurement related Header Fields. These are typically things that do change from run-to-run. An example of this would be a Serial Number, Incremental Part Number, etc.
When you go to Multiple Report - Select report header parameters; you will see all of your possible Header Parameters, but you will notice there are two columns on the left. One is labeled Run, and one is labeled Measurement Plan. While you can activate both Run and Measurement Plan for any Header Parameter typically you activate Run for Measurement related Header Fields, and Measurement Plan for Part related Header Fields.
When you activate the Measurement Plan option you will have access to these in Resources - Printout header parameters. When you activate the Run option you will have access to these in the Run screen inside of Report header data.
Please see my above response. It is typically ill-advised to activate both Run and Measurement Plan options. For example, there is no reason to see Drawing Number/Revision from the Run screen as that shouldn't change from run-to-run.
