Calypso 4.4 Disk
Wondering if anyone has a 4.4 disk that i could use to try and fix my issue? I only have the 4.0 license and don't have a disk.
Thanks,
Wade
Do you have a Zeiss portal login? I'm not sure if the 4.0 version is on there for download, but might be worth a look.
I have downloaded Ver.4.6 but it wants me to uninstall 4.4 first. I didn't want to do that till i had a disk. And i think someone here told me that my 4.4 license will only work for 4.4 and lower?
With regards to upgrading from 4.4 to 4.6, is the license you have for 4.4, or is it for a version between 4.6 and 5.6? Licenses up to 5.6 are able to be utilized for older versions of software(5.4,5.2,5.0,etc). The licensing methodology was changed with 5.8, so licenses for Calypso 5.8 or newer are not able to be utilized for Calypso versions older than 5.8. If you do not have a license for a version between 4.6 and 5.6 already installed and active, you will not be able to utilize any version newer than 4.4 (and if you do have a license for a version between 4.6 and 5.6 it will only be able to be used for that version or older. A 5.4 license will not work for 5.6, etc). You will also not be able to obtain or activate a license for these older versions of software, as the licensing system for these older versions was decommissioned a number of years ago.
Off topic, I know, but you're lucky I've already thrown away my folder full of original UMESS 300 upgrade disks 2 weeks ago 🤣
LOL good one on the 3D print
Not sure of the date on these in the software drawer, I've never seen a Dat72 storage tape. 5574_764bf936490189d26bb13405e691ede4.jpeg
