Turn on/off specific reports based on user input
Currently we have a program which has both an in-process measurement, as well as a final. Which iteration of the program is run is based on which miniplan the user chose at the beginning of the run. Each report has a bubble print which shows specific information based on which program has been run. Is there a way to use PCM to activate/deactivate certain report templates based upon user input (tied to miniplan selection).
  • 3 weeks later...
Here are a few PCM commands related to setting your output protocol.
getRunID()
getRunID() Check if complete or miniplan is executed
defineProtocol()
defineProtocol(Keyword,Functionvalue(s)) Flexible printout controlled by pcm
presentationOff()
presentationOff() Presentation protocol off
presentationOn()
presentationOn() Presentation protocol on
setElementsForProtocol()
setElementsForProtocol() Set characteristics to be printed in protocol
setProtocolOutput()
setProtocolOutput(protocol type, print function) Set printout independent from CNC start settings
setProtocolSetting()
setProtocolSetting(setting, value) Access to protocol settings
– setProtocolSetting("databaseSyncAfterRunFinished", true)
– setProtocolSetting("databaseSyncAfterRunFinished", false)
