[Zo...] Posted May 26, 2023 Share Posted May 26, 2023 Hi All, I tried to search for this but had no luck finding anything, sorry if it is a repeat question 🙂 i am trying to add translation values from a best fit Curve into result page. basically, i am looking for something like "getActual("2D Curve PZ").xTrans" that I can call using Result element image below shows what elements i am trying to extract Link to comment https://qualityforum.zeiss.com/topic/7862-best-fit-translation-values/ Share on other sites More sharing options...
[Th...] Posted May 26, 2023 Share Posted May 26, 2023 Funny how close you got by guessing. The correct attributes are transX, transY, and transZ. It always reports in millimeters (at least as of Calypso 2020) so if you ever find yourself needing to report in US customary units you'll have to convert it manually. 1 Link to comment https://qualityforum.zeiss.com/topic/7862-best-fit-translation-values/#findComment-34086 Share on other sites More sharing options...
[Ra...] Posted May 19 Share Posted May 19 (edited) Â Anyone know why I'm receiving this error? It is a recalled 2D curve, with best fit enabled within the feature. Â Edit: Figured it out. I need to create an alignment and get the translations from the alignment. Edited May 19 1 Link to comment https://qualityforum.zeiss.com/topic/7862-best-fit-translation-values/#findComment-150810 Share on other sites More sharing options...
[Ch...] Posted May 26 Share Posted May 26 I have a similar question about this topic. Does anyone know why when I recall the rotation values it reports the absolute value?  For example, I use getActual("Alignment, 8mm Rotor Profile").rotZ, the rotation value in the alignment is negative, but it reports it as positive.  I'd like to graph and see trends vs positive vs negative rotations, but can't with how its reporting. It's not a showstopper, but it sure would be nice.  Link to comment https://qualityforum.zeiss.com/topic/7862-best-fit-translation-values/#findComment-151080 Share on other sites More sharing options...
[Ch...] Posted May 26 Share Posted May 26 Scratch this. I found it was just inverting the sign. Easy fix, I just inverted my sign in the formula. 1 Link to comment https://qualityforum.zeiss.com/topic/7862-best-fit-translation-values/#findComment-151094 Share on other sites More sharing options...
[Iv...] Posted May 27 Share Posted May 27 Please sign in to view this username.  out of curriosty, are you using the new GD&T engine? If so, is this an area where the newer GD&T engine does not cover, and it requires the use of the additional sub-alignments? Link to comment https://qualityforum.zeiss.com/topic/7862-best-fit-translation-values/#findComment-151158 Share on other sites More sharing options...
[Ch...] Posted May 28 Share Posted May 28 Please sign in to view this username.  No, this is for a somewhat special use case for measuring twin screw rotors.  I use a rotor profile near the top for a clocking datum and then measure all other subsequent profiles back to that top datum that is best fit around the center axis.  I use the rotZ values to help us quantify any "twist" of the rotor. I also take lead scans and a variety of other things.   3 Link to comment https://qualityforum.zeiss.com/topic/7862-best-fit-translation-values/#findComment-151206 Share on other sites More sharing options...
[Iv...] Posted May 28 Share Posted May 28 Very interesting! Thanks for the extra info Link to comment https://qualityforum.zeiss.com/topic/7862-best-fit-translation-values/#findComment-151234 Share on other sites More sharing options...
