Suppressing PiWeb True Position data. Calypso 2019
viewtopic.php?p=20198#p20198
For the tolerances:
Go to Resources - Characteristics Settings Editor - Report - Transfer tolerances from the 'additional printout' option to PiWeb - either set the Measurement Plan to Off or the specific Characteristic to Off.
I use this code to replace the tolerance with a space when reporting additional information.
Upper Tol. text box:
${if Equal(String.Right(Qdb.Characteristic(2002),2), ".X") then " "
else if Equal(String.Right(Qdb.Characteristic(2002),2), ".x") then " "
else if Equal(String.Right(Qdb.Characteristic(2002),2), ".Y") then " "
else if Equal(String.Right(Qdb.Characteristic(2002),2), ".y") then " "
else if Equal(String.Right(Qdb.Characteristic(2002),2), ".Z") then " "
else if Equal(String.Right(Qdb.Characteristic(2002),2), ".z") then " "
else Qdb.Characteristic(2113)}
Lower Tol. text box:
else Qdb.Characteristic(2112)}
