[Nu...] Posted February 2, 2021 Share Posted February 2, 2021 Hello all, I need to check a dimension that are inscribed on draw as Ø, but the only way that i have to check it is by measure a point on surface and ask de polar coordinate to that point based on center. After that i have to multiply by 2 in order to achive the Ø. Its possible create one routine that multiply the measured value and give me the correct value (Ø)? Thanks Link to comment https://qualityforum.zeiss.com/topic/79-create-routine-to-measure-%C3%B8/ Share on other sites More sharing options...
[Be...] Posted February 3, 2021 Share Posted February 3, 2021 Hi, have you created a circle, cylinder or sphere? If yes, then you can create easily a diameter check on these elements via the I-Inspect. If not can you clarify your problem with some more images of the GOM software and your project and your created elements? Regards, Bernd Link to comment https://qualityforum.zeiss.com/topic/79-create-routine-to-measure-%C3%B8/#findComment-212 Share on other sites More sharing options...
