Calypso freezes on dual monitor setup
I have one machine where Calypso is constantly freezing. The problem started exactly when a second monitor was hooked up. The problem completely goes away when the second monitor is removed. Also, the problem is isolated to just Calypso; no other program does this.
I'm not sure where to even start looking for the problem. Any ideas?
https://qualityforum.zeiss.com/topic/7908-calypso-freezes-on-dual-monitor-setup/
I'd say start with your graphics settings. I am pretty sure there is an article about graphics settings on the knowledgebase. I would also check the monitor settings, I've seen a similar issue occur once when the refresh rate of the 2nd monitor was set slightly different (59.99hZ versus 60Hz on the other monitor)
