[Na...] Posted May 12, 2023 Share Posted May 12, 2023 Hello All, I cut a clip plane through a part - and put a curve element on the corner radius that was created by the clip plane. The program will scan that radius. I'm just not sure how to output the data. How do I output that radius? Thanks in advance. Link to comment Share on other sites More sharing options...
[Ma...] Posted May 14, 2023 Share Posted May 14, 2023 Please sign in to view this quote. You have to recall points into circle - or measure that radius as a circle with a few points ( depends on size ) - you can help with alignment from meny curves to get proper position of circle and then measure circle. [list=1] measure curve create alignment from many curves ( that one curve ) and select only translations which are needed ( example - only X,Y and rotation Z ) set feature alignment as newely created from curve and measure circle with at least 5 points More info would be better Link to comment Share on other sites More sharing options...
