Hole Depth
If I am interpreting the request correctly, an option may be to measure the OD of the shaft,then measure the hole as a cylinder. Create an intersection between the shaft od and the hole cylinder(you may need to try different intersection settings to get this to work as desired-unfortunately I am not in a position to test this myself), then use this intersection and the measurement of the bottom of the hole to get the distance.
https://qualityforum.zeiss.com/topic/7976-hole-depth/#findComment-34708
  • 3 weeks later...
