[Na...] Posted April 20, 2023 Share Posted April 20, 2023 How would I measure from the OD of a shaft - to the bottom of a hole in that shaft? Thanks in advance Link to comment Share on other sites More sharing options...
[Ma...] Posted April 21, 2023 Share Posted April 21, 2023 ❓ Nathaniel, please can you explane better what du you need? Drawing/sketch. Regardas. Link to comment Share on other sites More sharing options...
[Na...] Posted April 21, 2023 Author Share Posted April 21, 2023 Hello Marti. I've attached a MS Word file that explains what I'm trying to accomplish. Thanks for reaching out. Zeiss Question.docxFetching info... Link to comment Share on other sites More sharing options...
[Da...] Posted April 21, 2023 Share Posted April 21, 2023 If you have recent enough version of Calypso, Caliper Distance would be worth trying. Link to comment Share on other sites More sharing options...
[Mi...] Posted April 24, 2023 Share Posted April 24, 2023 Hello Nathanial. You can try to use "Result Element" (In German: "Resultatselement") to calculate that X value based on the Position and Radius of your circle minus the value of the holeground. Link to comment Share on other sites More sharing options...
[Ke...] Posted April 24, 2023 Share Posted April 24, 2023 If I am interpreting the request correctly, an option may be to measure the OD of the shaft,then measure the hole as a cylinder. Create an intersection between the shaft od and the hole cylinder(you may need to try different intersection settings to get this to work as desired-unfortunately I am not in a position to test this myself), then use this intersection and the measurement of the bottom of the hole to get the distance. Link to comment Share on other sites More sharing options...
[Na...] Posted May 12, 2023 Author Share Posted May 12, 2023 Thanks. Link to comment Share on other sites More sharing options...
[Na...] Posted May 12, 2023 Author Share Posted May 12, 2023 Thanks Marti. Link to comment Share on other sites More sharing options...
