Error using the "Geometry" Package
When using any script of the "Geometry" Package, I've got an error (see below)
Could you tell me what's the problem ?
Thanks a lot,
Hello,
you need a VMR license for this script. That's probably wrong and should be changed, but currently you need this license.
Regards
Matthias Aalto
Matthias,
Thanks a lot.. should be "strange" that you need the VMR licence for this script but it was in the first created for design fixture or colision box in a scanbox... So I coul'd understand and I have a VMR licence on my other PC station.
Still, you have 2 choices for now
- let the package available for everyone
- change the "licence needed" for the package and add the "VMR Licence"
Regards,
Julien
You are right. The current state is not correct. The package should be available for everyone, so I removed the requirement for the VMR license. Will be corrected in version 2022. Thank you for reporting this error.
Regards
Matthias Aalto
