Circle path for plane feature
Hi all, I'm hoping someone can point me in the right direction regarding circular paths for planar features. I am trying to measure the flange face around a large sphere and have set a circle path for the plane in question. When I execute the feature, the stylus moves to the Z+ clearance plane in between each point, but I would like to have the probe travel around the diameter of the sphere instead. Is this feasible? Any advice would be greatly appreciated, thanks!
https://qualityforum.zeiss.com/topic/7990-circle-path-for-plane-feature/
Hijacking....
Can you explain what both of those actually mean?
The help files are useless.
Arc Motion: Activates or deactivates arc motion.
Form-related travel within strategy: Depending on the feature type, the navigation paths are calculated optimally, thus avoiding, in the case of a cylinder for example, that navigation paths are too long because of their reference to a possible sphere.
Also OP, I believe the setting you want is under the special tab assuming:
You are measuring a Plane
The strategy is a circle path set to SINGLE POINTS
Then in your strategy settings, look at the Basic Options and Special Settings tab.
In special settings, check off Fixed path. This will make the probe travel in an Arc from point to point.
