[Ch...] Posted June 1, 2022 Share Posted June 1, 2022 Greeting all. From the little I've read on the forums folks are leaning towards GOM for analysis of point clouds generated by the Metrotom series machines. I have yet to convert fully as CALYPSO is basically my second language, but here's the issue. When loading a point set into my program/measurement script, I'm able to do so seamlessly part after part. However sometimes I get this error yelling at me, after trying to open a point cloud, that states "Incorrect input values or CT dataset too large for the memory." The only way around this is to reboot CALYPSO, which is a pain. Is there a box somewhere that I can check to parse the memory after a new file is loaded? Is this what is causing this issue? Any insight would be helpful *outside stating to use GOM 😭 😭 😭 Link to comment Share on other sites More sharing options...
[Je...] Posted June 1, 2022 Share Posted June 1, 2022 I'm interested to hear how you solve this one, Chad. I've been hearing the same info. I may push for a Metrotom purchase in the near future. Until recently, I was set on using Calypso to operate it, much for the same reason you mentioned of fluency with the software. The more I investigate the issue, the more it appears that GOM Volume Inspect and Calypso are designed for different tasks. This doesn't answer your question, but I think of the situation like this: The guy in the photo below made a "boat" from a truck last year that he launched in the Gulf of Mexico. It moved about 3-4 miles per hour. Can it really be said that this is a boat? . . Calypso can "handle" point clouds, but it's coughing and choking and crying the whole time. Link to comment Share on other sites More sharing options...
[Ri...] Posted June 1, 2022 Share Posted June 1, 2022 Please sign in to view this quote. Have you reached out to Zeiss directly for assistance? Sounds like there is a memory leak somewhere if a Calypso reboot temporarily solves the issue. Link to comment Share on other sites More sharing options...
[Ch...] Posted December 2, 2022 Author Share Posted December 2, 2022 I'll reach out to them with a service request. It's not just loading point clouds, sometimes when I've got a SUPER large program it will say it cannot load because of insufficient memory... And I have PLENTY of that, in my computer... eh not personally though 😜 Link to comment Share on other sites More sharing options...
[St...] Posted May 8, 2023 Share Posted May 8, 2023 Hey - Guys I found a work around after months of dealing with this issue. ill add a power point soon! Link to comment Share on other sites More sharing options...
