Super easy Calypso 101 Question part 4 Default Reports
I literally had just opened OBS so I could make a video; and look who beat me to it.
Thanks a lot Richard. Always stealing my glory.
HA HA HA That, my friend, is the secret to life. Go to Resources > Define report. Click on Default Report/Warning Limit. Tick "Background". See DM
I think it functionally disables the default report entirely, actually. I have a protdefinition I load into my measurement plans with this setting, and if I open the default report it's blank.
That is correct, but if you go to View - Multiple Report, it will force the Default Printout open as well.
I've found the Default Report to be slightly more persistent than phone calls about my vehicle's extended warranty. In addition to the two options already mentioned, I employ an autohotkey script in the background to immediately kill the default report without remorse.
You could use Python, Batch, VB or others, but here's the autohotkey script:
#NoEnv
SetBatchLines -1
; Loop continuously
Loop
    ; Loop through all windows
    WinGet, windowList, List
    Loop, %windowList%
        thisWindow := windowList%A_Index%
        WinGetTitle, windowTitle, ahk_id %thisWindow%
        ; Check if the window title includes "CALYPSO Default Report"
        if (InStr(windowTitle, "CALYPSO Default Report"))
            ; If it does, close the window
            WinClose, ahk_id %thisWindow%
    ; Wait for a short period before looping again
    Sleep, 1000
I find this very annoying, too!
After a few measurements there are still the protocols of the previously measured parts opened in the taskbar.
I circumvent this by creating a batch file "inspection_start_pcm" or "measurement_end_pcm.txt" in the general directory for measurement plans with the command
closeAllPlotts()
so that the open protocols will be closed at least.
