Planner - RDS CAA Broken
Hi all,
It appears that if I import an SSC and turn on the CAA function the offsets are getting compounded onto the stylus system.
This makes it impossible for me to test/program with an CAA enabled stylus system.
I can remember many years ago, that a CAA stylus system would not behave properly until you ran it through a qualification sequence. Haven't seen that in a long time though.
Tom,
I love you.
I ended up having to Qualify the MasterProbe, and perform a Fitting Position. Then on the CAA Stylus System, I set the XYZ to the correct values, and then performed a qualification. It now works correctly.
Where were you a few days ago??
Many thanks as always.
I just tested again. It appears that I only need to Qualify the MasterProbe, and perform the Fitting Position, and newly imported CAA Stylus Systems behave correctly (no need to correct the XYZ nominals).
