Adding Warning Limits to Print Out Header
Our program is set up so when the features exceed my predefined "warning limit", the color-coding turns yellow instead of the typical red you would see for a feature out of tolerance. Right now, the print outs tell us how many features were measured out of Tolerance (No. values: red) How can I add a section on the header to display the number of values that came back yellow?
Zeiss Print Out 1.jpgFetching info...
Add a text field and enter the following:
${Qdb.Measurements.OutOfLimit("WarningLimits")}
Create another text field and label as No. values: yellow
