[Bl...] Posted April 26, 2023 Share Posted April 26, 2023 While measuring a cylinder I want to switch one of two circle paths to three probing points. Currently I am having to manually probe this cylindrical feature because there is fixturing in the way. If I could set one circle path to probing points, I would be able to run the program and avoid the fixturing. Is this possible or will I have to make two separate circles? Link to comment https://qualityforum.zeiss.com/topic/8092-measuring-a-cylinder-with-probing-points-instead-of-circle-paths/ Share on other sites More sharing options...
[Ro...] Posted April 26, 2023 Share Posted April 26, 2023 Just change the "Number of sections" from 2 to 1 then you can change that section to be whatever you want. You can add as many individual sections as you need to avoid holes or obstructions. Just edit the "Start Height" to move them along.dgfgfdgfdgfkj.PNG Link to comment https://qualityforum.zeiss.com/topic/8092-measuring-a-cylinder-with-probing-points-instead-of-circle-paths/#findComment-35376 Share on other sites More sharing options...
[Bl...] Posted April 26, 2023 Author Share Posted April 26, 2023 Thank you! I did not change the number of sections because I still needed two sections but I did check the single points box, typed three points, and played around with the start angle/angle range until I was in the right spot. Link to comment https://qualityforum.zeiss.com/topic/8092-measuring-a-cylinder-with-probing-points-instead-of-circle-paths/#findComment-35378 Share on other sites More sharing options...
