[Be...] Posted April 25, 2023 Share Posted April 25, 2023 Hello everyone, I'm trying to simplify a program by using a macro. In the macro both a stylus and the O-inspect camera sensor are used. When I run the macro in the main program, all features are probed/scanned with its respective sensors as it should be. Only the camera and lighting settings are not transferred from the macro program. In case the last feature before the macro was scanned with the camera, the software uses the camera and lighting settings from this last feature. If the previous feature was probed with the stylus, the camera setting revert to the default camera and lighting settings. How can I get the macro to select the correct camera and lighting settings, which are set in the macro? Or is there another way to make the software use the correct settings? I'm looking forward to all of your suggestions! Link to comment https://qualityforum.zeiss.com/topic/8112-o-inspect-camera-used-in-macros/ Share on other sites More sharing options...
