Exceedance of characteristic
not sure..
maybe you could generate a function to avoid the calculation more than once...
featureName=""
exedTol=0
defineFunctionStart("exedTol")
exedTol=0
if getActual(featureName).actual > getNominal(featureName).tolerance.upperLimit
exedTol=getActual(featureName).actual - getNominal(featureName).tolerance.upperLimit
endif
if  getActual(featureName).actual < getNominal(featureName).tolerance.lowerLimit
exedTol=getActual(featureName).actual - getNominal(featureName).tolerance.lowerLimit
endif
defineFunctionEnd(exedTol)
then later just call the function:
featureName ="Diameter_Circle1"
circle1_exed= executeFunctionNamed("exedTol")
  • 3 weeks later...
//------- some commands for getActual----------
getActual("Diameter").dmisexceed //Exceed
getActual("Diameter").actual //Actual
getActual("Diameter").deviation //Deviation
getActual("Diameter").inTolerance // In tolerance? true or false
getActual("Diameter").inWarningLimit //In warning limit? true or false
