[Ri...] Posted March 6, 2023 Share Posted March 6, 2023 Are there PiWeb templates that can be imported for older versions of Calypso? I would like to have some GR&R templates. I have them in 2021 and 2022. Is Blueprint ballooning only for SBS and or Enterprise versions? Link to comment Share on other sites More sharing options...
[Gu...] Posted April 23, 2023 Share Posted April 23, 2023 Every original CALYPSO template for reporting has a version number on the first page. The first two numbers (yellow: here PiWeb reporting 8.2) are the PiWeb reporting version with which the template was created. The following number is the change index. If the CALYPSO reporting version is equal to or higher, the template can be swapped. The CALYPSO reporting version can be found as follows: Display a template: PiWeb reporting Monitor / Help /About => PiWeb reporting version Link to comment Share on other sites More sharing options...
