Results to File?
Program is created, part is measured, report is generated, programmed is saved... next...
I see that I can view the last part that was measured and reprint report. Is there a way to view multiple past reports?, or just the last?
I remember my trainer mentioning RESULTS TO FILE... Is this related, or something different?
Thank you for your help...
https://qualityforum.zeiss.com/topic/8150-results-to-file/
Results to file is used if you want to output results to an external data collection software. I have used it extensively with QC-Calc from Prolink. If this is the case you have to map QC-Calc to where is the data coming from the CMM being saved and it will generate a database and update it automatically every time a part is run.
https://qualityforum.zeiss.com/topic/8150-results-to-file/#findComment-35664
Results to File is how we collate our data. The .chr file has all the data for our reports.
We use Excel Power Query to load the data into Excel.
Then use pivot tables based on the Query to populate the Report sheet.
We also use the .chr file to import into JMP statistical software.
https://qualityforum.zeiss.com/topic/8150-results-to-file/#findComment-35666
  • 4 weeks later...
