[Aa...] Posted April 18, 2023 Share Posted April 18, 2023 Sorry, this is a bit of a newbie question. Up until now, I've never had much use for the report types in question. However, in the interest of automating entry of our results into a separate reporting system, I need to ask: Default Printout and Compact printout: - What is omitted from compact to make it more compact than default? - Are characteristics' results included in both or just one? - If I specify how they are named in Resources>Name for output files..., will they be saved automatically? Link to comment Share on other sites More sharing options...
[To...] Posted April 18, 2023 Share Posted April 18, 2023 Please sign in to view this quote. - I find there is a lot of redundancy in the Default Printout, i.e. every time a feature is referenced, it will print the data on it. - Characteristic results are in both. - Yes, Name for output files will work for both. I just tested it with 2022. Link to comment Share on other sites More sharing options...
[Is...] Posted April 19, 2023 Share Posted April 19, 2023 I’m using the compact printout to export data to our server (successfully).. You can customize it a little bit in the definition of the multiple report. Some headaches to deal with: - Some formatting rules change depending on the output language and not for all characteristics. - If you want to transfer attributes is easier to handle them setting a list (i.e. using text element) instead of the protocol header. Link to comment Share on other sites More sharing options...
