axis straightness ref
I think Calypso only has provision for surface straightness, not derived median line.. When you construct a virtual condition cylinder, its axis is a perfect geometry. I would try measuring 3 circles, then construct a 3d line from that. See if it gets you an option to select. This callout is actually a bonus of sorts regarding rule #1. Your local size still needs to be within tolerance,but perfect form is variable ?2374_c6d6a14e63b2b5edd76ce31668413d06.jpg
Can you use a series of circles, recall into a 2d Line and then evaluate with Straightness Ref?
In Simulation I am able to this, but I am not sure if it is capable.
