Goodbye, older friend.....
This one is even older than Norbert's old friend. Installed 1985, originally running Zeiss "Comet" software (an Americanized version of UMESS 200 I think) on an HP 9836 computer. has been moved three times over the years. The only real upgrade has been to a used computer running UMESS 300 20 years or so ago. It will be replaced with a Prismo 10 Ultra in a few weeks.
20230331_065402.jpg20230331_063816.jpg20230330_113918.jpg20230330_113852.jpg20230330_113808.jpg20230330_113756.jpg20230330_113741.jpg20230330_093404.jpg20230330_093351.jpg
Awwwwww! 😭
I remember having seen a few machines with this very old joystick box and controller back when I had my training at Zeiss Oberkochen in 1990.
Like I said: nearly undestroyable 🤣
😮 wow what a cool CMM.
it's really sad, most of the "old parts" still work´s fine 😭
In 1985 I didn't know what to measure 🤣
I'm not sure which is older the CMM or the forklift. I think it's the CMM. The company has been in business since 1865 so both are relatively new 🤣
No scanning, it's a really good trigger probe, I think they called it an ST probe. Piezoelectric trigger mechanism was very repeatable.
Yes, it's an ST. Stands for German _S_chaltender _T_astkopf (switching probe head)
We had the same head at first, but I wasn't too fond of it. Main problem was, it had 3 switches placed under 120 degrees around the head. To recognize a correct touch, one of the switches needed to open within a certain time frame after the piezo had triggered. The piezo alone would have been too sensitive.
If the switch didn't open within the time frame, the controller retried six times. If that was unsuccesful too, the machine errored and the program stopped. Depending on where that happened, you would have had to run the program from the start again and hope it'd work this time.
Because of the three switch positions there were preferred directions in which the touch almost always worked, and others where you could already smell failure. It was always suspenseful to watch such a program run. 🤣
First CMM I ever had to work with was a Sheffield Cordax in1988. Operators always coming back saying "my bore mic doesn't measure it as that diameter, why should I trust the dimensional spread".
It was a piece of junk in my opinion. 164_8fba0f4508cf5eaa92a445ffd0a4d7c3.jpg
