[Mi...] Posted April 3, 2023 Share Posted April 3, 2023 How do you handle profile to a single datum. I get prints all of the time with a call out of profile to a single datum and Calypso tells me " Evaluation of characteristic not possible". Right now I have been adding datums to further restrict the callout and it calculates but I dont think I should have to add to the reference frame to get profile. Any ideas thanks in advance Link to comment Share on other sites More sharing options...
[Mi...] Posted April 3, 2023 Author Share Posted April 3, 2023 I do not have curve or freeform have been using general surface to collect points. running a Contura select with vast XT Gold Head version 6.8.24 Link to comment Share on other sites More sharing options...
[Ma...] Posted April 3, 2023 Share Posted April 3, 2023 Depends on kind of datum. Usually you just fill up same feature to all datum fileds. Link to comment Share on other sites More sharing options...
[Mi...] Posted April 4, 2023 Author Share Posted April 4, 2023 thanks for the reply Martin The datum is a plane and the profile is all around a slot rising from the plane. I will give that a try filling datum fields with all the same datum. thanks for the idea. Link to comment Share on other sites More sharing options...
[Mi...] Posted April 4, 2023 Author Share Posted April 4, 2023 That worked for me. cannot believe it was something so simple thanks Link to comment Share on other sites More sharing options...
[Ma...] Posted April 4, 2023 Share Posted April 4, 2023 Please sign in to view this quote. I was using that until i found, that using freeform bestfit was giving better results. I had a part, where i had to report surface profile without datum - somehow i could not use profile without alignment, so i used cylinder instead - it was giving way worse results. Link to comment Share on other sites More sharing options...
[Ri...] Posted April 4, 2023 Share Posted April 4, 2023 Please sign in to view this quote. Yeah - it really just depends. You need to check the Default Printout to see if it performed a Best Fit or not. Sometimes it just defaults back to the Base Alignment or does what it wants to do. Link to comment Share on other sites More sharing options...
[Ri...] Posted April 5, 2023 Share Posted April 5, 2023 Please sign in to view this quote. Profile with no Datum = Form Only. In the case of a Plane, reporting Flatness and Form yields identical result. Link to comment Share on other sites More sharing options...
[Ri...] Posted April 5, 2023 Share Posted April 5, 2023 Please sign in to view this quote. Unless it is a closed loop, then the size is taken into account. Link to comment Share on other sites More sharing options...
