Setting Up Layers in AutoRun
How do you setup subfolders/layers in AutoRun? I'd like to have programs in AutoRun separated by Customer in subfolders that you can open up, then choose which part program to run from there.
Thanks!
I would suggest using the first or original layer as a Home page with a table of contents. Then, add layers or desks for each customer.
On the home page, you can create "links" to each customer page. And, on each customer page, create link back to the home page.
When you open the autorun, it will always open to the original layer or home page.
You can also force autorun to open with log in user profiles. Then you have control over what miniplans, rapid speed etc. per program by define run parameters
