PMI
Has anyone started using PMI to program from the CAD model? Thoughts of is it safe and is it better than other programming methods?
I've done several demos for customers and it is getting better. It is not a 1 button solution for some parts. In other words, if you're using multiple stylus systems, you still have to choose them. If you use default measurement strategies, then you'll need to verify those, or create strategies individually. It also depends on the quality of the PMI in the cad file. I think it can work.
Hope more people start using it. It looks good with the CAD CUBE. I tried to put one of our CAD models with PMI in today and it would not give me the PMI tab like it had on the cube. I will get with our drawing guru Monday and see what we missed. I did turn it on to Form and position (PMI) in CAD settings.
