Can PCM control selections of a Pattern (In a feature)
I have a surface, its been broken down into 4 Planes.
Plane1 - Is the perimeter scan.
Plane2 - Runs a scan around features and is in a 6x Pattern.
Plane3 - Runs a scan around features and is in a 6x Pattern.
Plane4 - Runs a scan around features and is in a 5x Pattern.
If I create a Miniplan (ex: Op10 Quick) can I use PCM to specify which Pattern Index's are to be ran?
Plane2 - Run 3 of 6 Indexes. (1; 3; 6;)
Plane3 - Run 3 of 6 Indexes. (1; 3; 6;)
Plane4 - Run 3 of 5 Indexes. (1; 3; 5;)
All help is appreciated.
I do know how to get specific indexes thank you!
Other than that, I don't know the language they are using and it wont translate for some reason.
