[Ri...] Posted April 1, 2023 Share Posted April 1, 2023 I have a surface, its been broken down into 4 Planes. Plane1 - Is the perimeter scan. Plane2 - Runs a scan around features and is in a 6x Pattern. Plane3 - Runs a scan around features and is in a 6x Pattern. Plane4 - Runs a scan around features and is in a 5x Pattern. If I create a Miniplan (ex: Op10 Quick) can I use PCM to specify which Pattern Index's are to be ran? Plane2 - Run 3 of 6 Indexes. (1; 3; 6;) Plane3 - Run 3 of 6 Indexes. (1; 3; 6;) Plane4 - Run 3 of 5 Indexes. (1; 3; 5;) All help is appreciated. Link to comment Share on other sites More sharing options...
[Da...] Posted April 1, 2023 Share Posted April 1, 2023 Please sign in to view this quote. Is reply from Patrick of any help to you? -> viewtopic.php?p=49493#p49493 Link to comment Share on other sites More sharing options...
[Ri...] Posted April 3, 2023 Author Share Posted April 3, 2023 I do know how to get specific indexes thank you! Other than that, I don't know the language they are using and it wont translate for some reason. Link to comment Share on other sites More sharing options...
