Formula to read Sigma of stylus
Hello everyone, I’m trying to make a qualifying of more probes from the rack. I entered the individual -recalibrations and now I need to see the results at the end. What formula can I use in the result element to extract the calibration sigma of each individual stylus?
Tnx
If you go to C:\Program Files (x86)\Zeiss\CALYPSO 7.4\userinfo\manuals\en-US you'll find a pdf help file on PCM. You'll find the answer.
After your run, if you select Default Report, I believe you'll get all of the results, including sigma.
