[Am...] Posted April 16, 2022 Share Posted April 16, 2022 (edited) How can I fix this error? Edited April 16, 2022 Link to comment Share on other sites More sharing options...
[Be...] Posted April 19, 2022 Share Posted April 19, 2022 Hi, are you using a script? This error occurs if you have specified the wrong value for a parameter argument for a command and the command is not able to interpret this parameter. Usually this shouldn't appear if you use the function by an interactive dialog. Regards, Bernd Link to comment Share on other sites More sharing options...
[Mi...] Posted March 10, 2024 Share Posted March 10, 2024 I had the same issue and fixed it by reducing the string length of my file/file path Link to comment Share on other sites More sharing options...
