Measuring an internal spherical diameter in cnc machine
So we have a couple of parts that we are getting, and they have an internal spherical diameter of Ø.873-.874 (finishes at Ø.8755/.8758).
What are the best options for inspecting this diameter with the part still loaded in the cnc machine, not on the CMM?888_b82031e5f1caf8c709b3d6974c93b62f.jpg
We have one of those, except the tolerance for the spherical diameter is .0003". The Dial caliper gage is in .0005" increments.
Avoid this p.o.s if possible. The accuracy of .0015" is being generous. Repeatablity is worse. They also need "zero" at the range you are measuring.
