[Jo...] Posted March 13, 2023 Share Posted March 13, 2023 Hello All, So with crankshaft flange end chamfers and post end chamfers or valve seats you get the occasional "overball dimension" back to a datum surface. (ball in this case is 24mm w/60 degree conical chamfer) Is there a "canned" routine for this in Calypso after measuring said cone? I converted an old Quindos math routine with trig and updated it to work in parameters while grabbing a dimension from the cut cone calculation routine. Seems to work as I get close to anticipated nominal. I just wanted to test it with a Calypso routine. Thanks in advance!! Link to comment Share on other sites More sharing options...
[Cl...] Posted March 13, 2023 Share Posted March 13, 2023 I've got something that might work, but depends on a few variables. Can you post any pics or drawings so we can get a look at exactly what you want? Link to comment Share on other sites More sharing options...
[Ri...] Posted March 13, 2023 Share Posted March 13, 2023 I can't recall the author of this file. Hope it helps.Sphere in Cone Height.pdf Link to comment Share on other sites More sharing options...
[Ri...] Posted March 13, 2023 Share Posted March 13, 2023 Here is the last instructions I made for this topic. In Calypso 2021: Create a Half Cone Angle Characteristic for your Cone Create a Result Element and use the following formula: ((cos(deg(getActual("Half Cone Angle1").actual))*Gage Ball Radius)*2) Create a Cone Calculations Feature, select Position Definition, and use the following formula: (getActual("Result Element1").actual) + ((1/cos(deg(getActual("Half Cone Angle1").actual)))*Gage Ball Radius)+Gage Ball Diameter Link to comment Share on other sites More sharing options...
[Ri...] Posted March 13, 2023 Share Posted March 13, 2023 In addition - Ted Hurlbutt wrote up some instructions as well. Link to comment Share on other sites More sharing options...
[Jo...] Posted March 13, 2023 Author Share Posted March 13, 2023 Please sign in to view this quote. It looks as though there is a pdf for doing this in Calypso that is pretty much the math I had. I attached a screen shot as to what I'm looking at. Thanks.over_ball.jpg Link to comment Share on other sites More sharing options...
[Cl...] Posted March 15, 2023 Share Posted March 15, 2023 There might be a better, simpler way, but what I do is, if the ball sits in a V or a cone, you can scan two opposing lines (cone) or two opposing planes (V) and move them in towards the center the nominal ball radius. Then intersect both. This gives you the ball center. You then recall that intersection into a theoretical circle. Now you can use caliper distance to get the 163.5 Link to comment Share on other sites More sharing options...
[Ri...] Posted March 15, 2023 Share Posted March 15, 2023 Please sign in to view this quote. I just learned something similar to this. I scan two opposing lines. Drop in a Tangent element, select the Lines with a window box and assign a diameter. It creates the diameter feature tangent to the two lines. Put in a Caliper element and assign the min/max properties for your measurement. Link to comment Share on other sites More sharing options...
[To...] Posted March 15, 2023 Share Posted March 15, 2023 How about adding a measurement over ball construction to Calypso..... 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted March 17, 2023 Share Posted March 17, 2023 Please sign in to view this quote. I just want Datum Shift. Link to comment Share on other sites More sharing options...
[Jo...] Posted March 21, 2023 Share Posted March 21, 2023 That would be great! They already have "Cone Calculations", why not just add "Over-ball Calculations" or something to that matter. For me, I use this simple Gage-ball calculations for finding either Top or Bottom of Gage-ball: [img][/img] For this example, I use a simple Alignment (Plane1 and Cone1). 1) Intersect Cone1 with Cone1. 2) Create a Theoretical-Sphere that represents your Gage-ball and add this formula to whichever axis the cone is on. 3) Intersect the Cone1 with Theoretical-Sphere. Select either Result1 or Result2 that correspond to your measurement. [img][/img] Hope that helps. Link to comment Share on other sites More sharing options...
[To...] Posted March 21, 2023 Share Posted March 21, 2023 Please sign in to view this quote. Would a cone calculation with the Position Definition set to D =0 work for step 1? Link to comment Share on other sites More sharing options...
[Jo...] Posted March 23, 2023 Share Posted March 23, 2023 Yes. That would be the same. Just replace "Tip of Cone" with "Cone Calculation" in the formula. For this example: getActual("Cone addition1").y-(0.28125/2)/sin(deg( getActual("Cone1").apexAngleHalf)) Link to comment Share on other sites More sharing options...
[Br...] Posted March 23, 2023 Share Posted March 23, 2023 A different version of the same issue. A Vee shaped groove with a callout to an overball dimension straight and parallel to a plane. I am a rookie so use small words Link to comment Share on other sites More sharing options...
[Ri...] Posted March 27, 2023 Share Posted March 27, 2023 In away there is a function. Scan two opposing lines on the cone surface. See: Cadcube_Cone_Lines.JPG Use tangent element Enter 2d Line1 Enter 2d Line2 See: Cadcube_Tangent_Lines.JPG Set desired Diameter (Ø29) See: Cadcube_Tangent_Ø29.JPG Use Caliper Distance tangent element Plane1 See: Cadcube_Tangent_Caliper Dist.JPGCadcube_Tangent_Caliper Dist.JPGCadcube_Cone_Lines.JPGCadcube_Tangent_Lines.JPGCadcube_Tangent_Ø29.JPG Link to comment Share on other sites More sharing options...
