[ni...] Posted March 23, 2023 Share Posted March 23, 2023 Hello, I would know what is the special menu (extra/special menu) and how to use it ? slts Link to comment Share on other sites More sharing options...
[Ju...] Posted March 23, 2023 Share Posted March 23, 2023 That's where you access Tetris. SpecialMenu.jpgFetching info... Link to comment Share on other sites More sharing options...
[Mi...] Posted March 23, 2023 Share Posted March 23, 2023 Please sign in to view this quote. .... and how does one get that un-greyed out? Link to comment Share on other sites More sharing options...
[ni...] Posted March 23, 2023 Author Share Posted March 23, 2023 Yes, but tetris doesn't work on my calyspo. " executeCode" isn't recogniesed on calypso 5 so i'll try the second method without succes. I don't think this special menu is here only for tetris, so that post ... Slts Link to comment Share on other sites More sharing options...
[No...] Posted March 23, 2023 Share Posted March 23, 2023 The special menu can be used for custom menu functions, but you can't define its contents from within Calypso. It's for special use cases and is meant to be pre-configured by Zeiss. I once knew how to set it up, but now that I'm typing this I realize I forgot 🫣 🤣 Link to comment Share on other sites More sharing options...
[ni...] Posted March 23, 2023 Author Share Posted March 23, 2023 is there a third way to play tetris without "execute code" and without the very-special-menu-only-for-zeiss ? Link to comment Share on other sites More sharing options...
[Ro...] Posted March 23, 2023 Share Posted March 23, 2023 #1 save anything you have in progress. #2 Press ALT+F4 to make it not grey. Do not hit ALT+F4, its just an old and mean trick i used to use on people back in the 90's and 00's when the internet was basically a huge Chat Room & forum. Alt+F4 will simply close whatever window you currently have open. Back in the day when someone would have any problem in the chat rooms, my answer would always be that Alt + F4 would fix that problem, then a couple seconds later you would see the persons name "Has left the room", and i would laugh. Link to comment Share on other sites More sharing options...
[Th...] Posted March 23, 2023 Share Posted March 23, 2023 On par with "delete system32 to make your computer run faster" Link to comment Share on other sites More sharing options...
[ni...] Posted March 24, 2023 Author Share Posted March 24, 2023 @ Roberto @Thomas : you are horrible, I like that 🤣 Link to comment Share on other sites More sharing options...
[Ri...] Posted March 26, 2023 Share Posted March 26, 2023 If the menu doesn't ungrey, and you cant play Tetris, Do this: Control-Alt-Sledghammer This fixes any computer/Laptop that isn't working properly. 😃 Link to comment Share on other sites More sharing options...
[Ka...] Posted March 27, 2023 Share Posted March 27, 2023 Don't be egotistical and share Tetris for all colleagues who want to start a test plan. If the task is successfully solved, then you are ready to go. Simply place an Inspection_pre_start_dialog.bat in each inspection plan directory and call Tetris in it. It will be a lot of fun 😃 Link to comment Share on other sites More sharing options...
