Special Menu
Yes, but tetris doesn't work on my calyspo.
" executeCode" isn't recogniesed on calypso 5
so i'll try the second method without succes.
I don't think this special menu is here only for tetris, so that post ...
Slts
The special menu can be used for custom menu functions, but you can't define its contents from within Calypso. It's for special use cases and is meant to be pre-configured by Zeiss. I once knew how to set it up, but now that I'm typing this I realize I forgot 🫣 🤣
#1 save anything you have in progress.
#2 Press ALT+F4 to make it not grey.
Do not hit ALT+F4, its just an old and mean trick i used to use on people back in the 90's and 00's when the internet was basically a huge Chat Room & forum. Alt+F4 will simply close whatever window you currently have open. Back in the day when someone would have any problem in the chat rooms, my answer would always be that Alt + F4 would fix that problem, then a couple seconds later you would see the persons name "Has left the room", and i would laugh.
If the menu doesn't ungrey, and you cant play Tetris, Do this:
Control-Alt-Sledghammer
This fixes any computer/Laptop that isn't working properly.
Don't be egotistical and share Tetris for all colleagues who want to start a test plan. If the task is successfully solved, then you are ready to go.
Simply place an Inspection_pre_start_dialog.bat in each inspection plan directory and call Tetris in it.
It will be a lot of fun 😃
