Record Manual Alignment Data
Hello,
Does anyone know if it is possible to record the actual values associated with your manual alignment?
I'm looking to add this to the report - don't ask why. Lol.
I have access to PCM if that helps, but I'm fairly ignorant when it comes to PCM, so I will need assistance on the coding if that is the case.
I appreciate any and all help.
Thank you.
If you recall saved alignment, then you can report it - just recall alignment without CNC in name.
For reporting characteristics without alignment change available, then you have to copy feature, change alignment and recall measured points.
Hmm. Didn't know you could recall an alignment like that.
Either way, I still have no way to access to actual values of those manual points.
I'm thinking this is possible if I was to run without a base alignment, but that just creates more work.
Alright I figured out how to do it. So I'm doing a 3-2-1 Alignment, so these steps will apply to that.
- Create your Base Alignment with your 6 points (make sure the Points are set to Plane-Point).
- Do not place a loop on the alignment.
- Switch your Base Alignment points to Manual Points.
- Copy your Base Alignment points, set these to CNC Points.
- Create a new RPS Secondary Alignment, set your Loop and break condition as needed.
- Enjoy
