CAD Scaling
Hello community!
I am hoping for a solution to a mistake I made. There was an older part with no cad model which I created through the Calypso features, but I did so with all units in millimeters instead of inches. Is there a way to scale all the features of a CAD Model by 25.4X within Calypso?
This might work.
If you have access to a CAD program (IE: SolidWorks, etc) open the CAD model and scale it accordingly.
Upload the newly scaled model in your CMM program.
Set your Units to the desired value, Inch or Metric.
It would mean that the model size would change correctly, but measurement features you already extracted from it would not. So if you created a 30 mm circle before scaling, it will still be 30 mm afterwards.
