Are there any other Speed settings?
I know we have speed setting at run time, and I know I can adjust the speed to enter a feature (such as a circle).
I have a probe that reaches under the part and across to the other side (I have to do this).
The speed is only slowed down (set at 30) upon entry of the circle.
Can I slow down the rapid speed of specific features?
Are you talking about how quickly it approaches the surface once inside the retract distance? If so, that is controlled with the Probing Dynamics setting.
Thank you, I do know about that one too.
I need to slow down the rapid speed of a probe for two features but I don't want to slow down the entire program.
That's what I have, what I see is operators smacking the big red panic button because it gets quite close to the part. Not only will the VAST head get close but the stylus itself is closer.
