[Xi...] Posted March 9, 2023 Share Posted March 9, 2023 what does 617 Safety Module mean? machine started driver off even machine is idle. TIA Link to comment Share on other sites More sharing options...
[Ju...] Posted March 9, 2023 Share Posted March 9, 2023 The machine may be sitting on an axis limit switch. Have you tried moving the head away from the sides of the table? Link to comment Share on other sites More sharing options...
[Er...] Posted March 10, 2023 Share Posted March 10, 2023 If I recall correctly this is the error for the "safety chain." If anything in the chain of switches or sensors detects a fault this error is tripped. The Zeiss tech said there was no way to know which one. It was simply a matter of eliminating each one until the culprit was found. This is similar to the "Drives Off" message which can be so misleading. viewtopic.php?p=34790&hilit=617#p34790 Link to comment Share on other sites More sharing options...
