[Ün...] Posted March 1, 2023 Share Posted March 1, 2023 Hello, I am trying to increase it to 25 metrics by modifying the 20 metrics report previously shared here, I edit the value as 25 in the table setting, but it still reports the last 20 results. Is there a setting section elsewhere in piweb or has piweb limited it to 20? what am i missing Link to comment Share on other sites More sharing options...
[Se...] Posted March 1, 2023 Share Posted March 1, 2023 Hello Ünal, maybe you will have to set it here: . Link to comment Share on other sites More sharing options...
[Ün...] Posted March 1, 2023 Author Share Posted March 1, 2023 Hello Sebastian, I want to save this report as a template and report the last 25 measurements after each measurement. It needs to be saved as pdf by creating multiple reports. I can do what you say in the Piwep monitor section. Link to comment Share on other sites More sharing options...
[Ka...] Posted March 3, 2023 Share Posted March 3, 2023 Hello Ünal, It should be possible to set the number of columns to infinite. Scroll down the numbers to 1 and one more ( less than 1 is infinite 🙂 ) If this not work, I see the only way to increase the page size of your template. regards Karsten Link to comment Share on other sites More sharing options...
